Author Topic: creation tools - along path problem  (Read 4037 times)
lukx
    • lukxCGI
« on: April 17, 2013, 01:29:32 pm »
I wanted to create hedges along paths so I used creation tools , choosed path and the problme is that some geometry is flying and not on the path :
What might be causing this?
Re: creation tools - along path problem
« Reply #1 on: April 17, 2013, 04:27:39 pm »
Is there a surface assigned ? If so, please check if Surface->Custom Edit Mode->Link to Surface is On.
lukx
    • lukxCGI
« Reply #2 on: April 17, 2013, 05:09:39 pm »
Thank you Carlos. when turning off link to surface helped :) And also UV mode helped :)
