Author Topic: 3dsmax Crashes when mirroring a spline  (Read 1090 times)
amitgedia
« on: December 12, 2019, 12:40:41 PM »
HI,
I was just trying to produce a scatter of the starter library and make it follow along the path (spline).
I create a plane then i create a spline, then selecting the plane i try to create FP, then select any model from the starter library to distribute, then in the distribution rollout i select path instead of image and the select the spline and the model gets distributed on the spline
When i try to mirror the same spline along any axis like a X-axis or Y-axis 3dsmax crashes
So is this a bug or is it the wrong steps that i am doing
here is the link for 3dsmax file for checking
https://wetransfer.com/downloads/a51c5f83ee602b7ff4bb00282e893edc20191212113756/e3c35aab124b71ff8528e15ca202856220191212113756/92028e
Note : 3dsmax 2017, V-Ray Next, FPP 6.2.2
Hope someone helps to fix this issue
Re: 3dsmax Crashes when mirroring a spline
« Reply #1 on: December 12, 2019, 01:51:22 PM »
Yes I can reproduce it.
Thank You for reporting! Our developer will look into it.
amitgedia
« Reply #2 on: December 12, 2019, 02:58:28 PM »
Thanks Rokas for the reply, i was just fiddling with FPP and 3dsmax after seeing Alexander VrayGuide's image when i encountered this issue
