Forest Pack => Forest Pro (*) => Topic started by: in3des on March 18, 2021, 08:27:57 pm
Title: forest color for non-forest object
Post by: in3des on March 18, 2021, 08:27:57 pm
I'm trying to render a tree with random texture for leaves.
Looks like ForestColor doesn't work on non-forest objects. (only first texture is rendering)
Is there any work around for this issue or some trick?
Thx.
Title: Re: forest color for non-forest object
Post by: Rokas on March 19, 2021, 07:56:25 am
Hi.
When You are using "forest color" map outside forestObject it works in Item mode only.
Element mode is only supported by ForestPack objects.
(https://i.imgur.com/6Uaa5c7.png)
Post by: in3des on March 19, 2021, 09:47:46 am
Thanks for the answer Rokas.
Is there any way to bring an object inside of forest but keep its current position?
Maybe some quick button get&place...
thx
Post by: Rokas on March 19, 2021, 09:48:52 am
There is script section and there is such a script (https://forum.itoosoft.com/forest-pro-(*)/scripts-for-forest-pack/msg12480/#msg12480) already.
Post by: in3des on March 19, 2021, 09:50:36 am
Oh, thanks a lot!
Will give it a try!
