Author Topic: Open FP Pro scene with FP Lite - and RC Lite vs Pro  (Read 2227 times)
Morne
« on: March 16, 2021, 03:37:46 pm »
Hi Guys
1) If we author scenes with the Pro version, using Pro features, but then open those same scenes with a Lite version WITHOUT rendering, will the objects be visible in viewport at least, or the result will be disabled?
2) If the original Pro scene is then opened and SAVED with the Lite version, will everything still be "correct" when later opened again with the Pro version?
....asking in terms of both FP and RC
Re: Open FP Pro scene with FP Lite - and RC Lite vs Pro
« Reply #1 on: March 19, 2021, 11:31:12 am »
It is not recommended to Work PRO ->Lite -> PRO
Only Lite-> PRO is without incompatibilities.
When You open PRO scene with Lite - You loose PRO features. You see the object to limited extent as PRO features are discarded.
You wont see all the items if there were more than 3 of them, their location might be wrong on Z axis etc....
You can edit the FP/RC objects with lite version, but depending on the edits- they might or might not be as expected when opened in PRO version later.
Everything will be correct when later opened with PRO version afterwards. It's just that You wont see correct result with Lite version.
