Author Topic: Forest displaying in viewport, but suddenly not appearing in render  (Read 3388 times)
IG2426
So I'm working on a big file with lots of crazy different forests. But then there is this one specific forest that suddenly stopped appearing in the renders (Vray 3.4). I tested out changing the distributed geometry, changing the areas and surfaces used or subtracted, but its all no use. At some point I had a working clone of it, and redid it from scratch, but still at some point it stopped appearing in the renders. I'm having a hard time troubleshooting it to get it to work, and it happened more than once with the same file. I want to attach the file, but its a way too large to be attached here.
Let me know what I can do..
Thank you!
Re: Forest displaying in viewport, but suddenly not appearing in render
« Reply #1 on: January 17, 2017, 04:11:46 pm »
Would you mind to send us your scene (ideally a simplified version of it containing problematic Forest objects) to have a look at it here? Thanks in advance.
IG2426
« Reply #2 on: January 17, 2017, 05:21:48 pm »
Thank you for the reply! File is sent :)
