Author Topic: FP & RC update that solves Delete Key  (Read 22914 times)
CharlyRT
« on: November 26, 2024, 10:09:40 pm »
I received a notificacion from FP and RC update mentioning that the latest update solves an issue with Delete Key.
Could you elaborate from this? Wich versions of 3ds Max are effected?
I have this issue with 3ds Max 2025, I havent had the time to try to uninstall iToo software because I need it all the time.
I attached a file showing the error
RealViz
    • RealViz
Re: FP & RC update that solves Delete Key
« Reply #1 on: November 27, 2024, 07:41:02 am »
I am also still having problems even after updating to new versions FP and RC. Max 2024.
RealViz
    • RealViz
« Reply #2 on: November 27, 2024, 10:38:10 am »
It seems that for old scenes you need to open and close the FP lister. That will probably fix everything. That's my observation. So thanks!
« Reply #3 on: November 27, 2024, 10:56:47 am »
In theory, this should now be fixed. However, if anyone continues to experience issues with the Delete key after installing Forest Pack 9.1.6 and RailClone 6.3.4, could you please check what specific behavior seems to trigger it? Thanks in advance for any suggestions.
brlv@brlv.co.il
« Reply #4 on: December 04, 2024, 08:45:14 am »
Hi ,
Delete button still doesn't work most of the time. Even after the latest updates .
VRAY 7 GPU
3DS MAX 2024
RealViz
    • RealViz
« Reply #5 on: December 04, 2024, 12:34:47 pm »
Hi ,
VRAY 7 GPU
3DS MAX 2024
Try turning FP and RC Lister on/off for existing scenes. It works for me. No need for new scenes. However, it is possible that there will be a problem with some more massive use of xrefs in which the bug overflows.
Morne
« Reply #6 on: December 20, 2024, 01:20:19 pm »
We just upgraded to the latest FP and RC versions and also experiencing this issue
as another workaround for now, select the FP object you want to delete then paste this in the script listener and press ENTER:
delete $
