Author Topic: Forest Edge Mode and VRay GPU  (Read 3182 times)
Morne
« on: March 24, 2022, 08:46:09 am »
Hi all
I'm getting black artefacts on the edges of my FP objects, with Edge mode enabled and using VRay GPU. Is this a FP or VRay GPU issue?
Render sample attached
« Last Edit: March 24, 2022, 08:49:09 am by Morne »
Re: Forest Edge Mode and VRay GPU
« Reply #1 on: March 24, 2022, 11:07:39 am »
Hi Morne.
I'm afraid that edge mode is currently not supported by V-Ray GPU. There are several limitations to implement features like
 Edge Boundary Checking mode for this render engine. The reason is that these features work at render time, and require a custom shader for each renderer (a piece of code which runs directly in the render engine). But V-Ray RT doesn't support any third-party shaders (there is no SDK, so we cannot write code for it).
I would suggest using the work-flow shown in the Grass Edges tutorial.
