Forest Pack => Forest Pro (*) => Topic started by: GT4405 on August 25, 2017, 11:38:47 am
We are having some issues with Corona 1.6 hotfix 1 and Forest Pack 5.4.0. We can´t make Corona and FP to work with EDGE mode enabled and ForestEdge map in Opacity slot, as we used to. I´m not sure if I´m missing something here but maybe there may be a bug?
We have tried to create a simple forest object, just scattering some boxes over a plane, and edge mode isn´t working at all.
Any help would be welcome, thanks in advance!
Julio
P.D.: we are using Win 10 up-to-date and 3DsMAX 2016
Hi, no problems here using same configuracion and Corona 1.6 Hotfix 2.
Please, test if the attached sample works for you.
Thank you very much for your fast support.
I´ve installed latest Hotfix (I had Hotfix 1 instead of 2), open your scene and it´s working like a charm.
I will check now in the comercial projects to see if problem is solved, then write again with results.
Julio
It´s working now in the commercial scene that we were having issues with. I suppose that the problem was the version of Corona...
Thanks for your help!
Julio
I'm glad the problem is solved. :)
Regards,
