Author Topic: When I reopen a scene, the custom materials revert back to preset defaults.  (Read 6754 times)
SQ7408
I have a few presets where I want to change the default Vray material to a Vray 2-sided material... but when I customized the materials and save the scene... the 2 sided materials are disconnected.
I have tried both merging the forest objects into the scene as well as the xref option but either way I keep losing my changes and it is driving me nuts!
Any help is appreciated, thanks!
« Last Edit: August 30, 2017, 01:48:23 am by SQ7408 »
As mentioned in this "V-Ray Material Override" post:
It is not safe to modify directly the "automaterial", because Forest keeps references to its source materials. Instead you should modify the material linked to item(s) - Custom Object(s) - Material(s). Any changes made this way, will be projected safely to the Forest's "automaterial".
Hope that helps.
