Author Topic: Forest pro 8.2.6 UI startup so slow!  (Read 7145 times)
steve3duk
« on: April 03, 2024, 02:37:56 pm »
Will this interface ever be updated with the latest 3dsmax UI performance improvements. It can take 10 seconds at least for the interface to appear.
Re: Forest pro 8.2.6 UI startup so slow!
« Reply #1 on: April 03, 2024, 03:09:13 pm »
I'm sorry to hear that you're facing these troubles. Would you mind specifying your current hardware configuration? Some CPUs (for example, we are aware of some versions of Threadrippers) were facing this kind of problem. Please feel free to check this article to see if that might help you.
Let me mention, that you can have visible just some roll-outs (these you are frequently using) - you can edit the Global Settings from the General rollout as desired (attaching screen-shot) to check if that helps.
Thanks in advance for any further comments on this issue.
