Author Topic: How to delete forest in scene  (Read 5994 times)
MS4538
« on: April 13, 2014, 05:44:43 pm »
Hi, I have created some forest in the sence( in layer there has forest 001 to forest 015), I wish delete forest 003 to forest 015,  how to do that ? when  select forest 003 ( or other ) in the view, I can't delete it by press delete key...
Re: How to delete forest in scene
« Reply #1 on: April 14, 2014, 09:40:33 am »
all Forest objects can be deleted in the same way as any object in 3D Max (by Delete key). Probably the most efficient way is through Manage Layers... window. You can do multiple selection using Shift or Ctrl key and then Select Highlighted Object and Layers. Please check attached screenshot.
If you hit Delete key and nothing happens please double check if the object is not frozen or in frozen layer. Selection Lock Toggle activated (by default assigned to space key) will block your selection so please double check also this option.
Please note that once working in sub-mode of Forest object to delete it you'll need to exit this mode (this behaviour is similar as working in sub-mode of any mesh object in 3D Max). Attaching screenshot showing this mode.
Hope this tips will help you with this trouble.
Kind regards,
