Author Topic: Grass clipping  (Read 3225 times)
Crayox
Grass clipping
« on: December 20, 2021, 08:49:57 am »
Hi guys,
I have these white lines on the field that don't want to render regular. I use standard builtin grass with edge clipping enabled. Tried several options off, like for camera clipping etc but I still get these results. Any ideas?
The area for lines is 20cm so not really that thin. It's a mesh object.
Thx
Crayox
Re: Grass clipping
« Reply #1 on: December 20, 2021, 08:51:22 am »
Oh and I'm using "large" presets...maybe I should use detail? Any way I can make large work here?
Re: Grass clipping
« Reply #2 on: December 20, 2021, 09:06:34 am »
In this case, I would use detail for the white lines. The patches that are used for large presets could very well fall outside of the clipping spline otherwise.
Crayox
Re: Grass clipping
« Reply #3 on: December 20, 2021, 09:34:04 am »
Yeah, thx...that was the problem :)
RealViz
    • RealViz
Re: Grass clipping
« Reply #4 on: December 20, 2021, 10:06:54 am »
For this case it would be much better to use ForestColor. Nothing needs to be clipped.
Edit:
For lines, use VrayDistance (if it is a Vray).
« Last Edit: December 20, 2021, 10:08:44 am by RealViz »
RealViz
    • RealViz
Re: Grass clipping
« Reply #5 on: December 20, 2021, 01:20:29 pm »
I created a very simple scene with no textures.
