Author Topic: forest invisible to camera problem (forest 5.2.0 and vray 3.50.03) [SOLVED]  (Read 3709 times)
FU1154
Hi, i've a problem rendering forest with "invisible to camera" option unchecked. i've got holes in my rendering and my alpha pass.
it happens sometimes and i don't what to do ;(
i need this pass with my base rendering with forest shadows but without the forest, can anyone help me?
Best regards
Tombook
« Last Edit: April 25, 2017, 03:44:35 pm by FU1154 »
Re: forest invisible to camera problem (forest 5.2.0 and vray 3.50.03)
« Reply #1 on: April 25, 2017, 03:15:37 pm »
It might be related to a high density distribution generating many overlapping objects and increasing Global switches - Max transp. levels (default value is 50) should fix it (sometimes may be necessary to modify Secondary rays bias also).
Anyway, please feel free to send us your scene to check it here. Thanks in advance.
FU1154
« Reply #2 on: April 25, 2017, 03:40:10 pm »
THANK YOU !!!
the max transp levels value was 999 so i was totally lost, but the second rays bais was set to 0.00, i set it to 0.002 and it seems to be good now.
you saved my rendering process!
