Author Topic: Surface  (Read 14050 times)
Bobby Parker
Surface
« on: October 01, 2024, 03:04:26 pm »
With the new release, my forest object isn't attaching to the surface. I have a spline over a plane and pick the spline for the path and the plane, but the Forest objects (bushes) do not sit on the plane.
Re: Surface
« Reply #1 on: October 01, 2024, 03:10:09 pm »
Hi Bobby,
When using a surface, its coordinates should align with the intended orientation of the Forest object. For example, a plane created in the Front view will interact differently with Forest objects than one created in the Perspective or Top view. To correct this, you can use the Utilities - Reset XForm - Reset Selected tool to reset the surface's local coordinates.
In case of any further troubles with it, please feel free to send us the scene (preferably simplified and including only the problematic object(s)) so we can take a closer look. Thank you in advance!
