Author Topic: Questions regarding Forest Color map  (Read 4695 times)
Michael
« on: March 14, 2022, 12:37:06 pm »
Hello forum!
I have a question regarding the "forest Color" map in 3ds max and vray.
I have 4 pine trees with the same multimaterial. Their needles have a forest color map with 4 different diffuse maps assigned to different  probabilities inside forest color. I have some green needles at 100% and some more brown yellowish at 30-40% and its set to Get ID from Element. I dont have any tint in the forest color map, and yet its assigning the maps not per element but it seems like its per item, it makes a whole tree brownish and then another green.
Any ideas to why this is?
Thanks a lot!
Re: Questions regarding Forest Color map
« Reply #1 on: March 14, 2022, 12:40:50 pm »
Thanks for the question.
Are you by any chance using proxies? There's a technical limitation with those that randomise by element isn't supported. If that's the case, importing or X-Reffing the mesh should fix the issue.
Michael
« Reply #2 on: March 14, 2022, 12:43:43 pm »
yes they are proxies. Thanks i will try by import or xref!
