Author Topic: animation from a group vs animated proxy  (Read 668 times)
Morne
« on: August 15, 2022, 04:24:42 PM »
Didnt animation use to work with groups?
I can now only get it to work if I collapse the group to an animated proxy
FP 7.4.2
Max 2022
VRay 5
Re: animation from a group vs animated proxy
« Reply #1 on: August 15, 2022, 04:31:45 PM »
Hi Morne,
I'm not sure I understand what type of animation you're trying to create with groups. Anyway, we did recently change the group behaviour with a new option that treats a group as a single object. You can use the old method by disabling the option called Keep Group Hierarchy.
Cheers,
Morne
« Reply #2 on: August 17, 2022, 03:08:24 PM »
Doesnt seem to work for me Paul
I have a cube 1000mm X 1000mm X 1000mm. On top is a tube. I set the tube to rotate in Z
I group the cube and tube together
Then I use this in FP. However no matter which way I set it in Animation settings, or in "Keep Group Hierarchy" ticked or not ticked, it just doesnt work
Only way I can get it to work is by making it am animated vray proxy
« Reply #3 on: August 17, 2022, 03:15:59 PM »
Hello Morne,
Now I think of it, I'm pretty sure that has never worked in Forest Pack. Whenever people have wanted to do this we've usually said that you should add an XForm modifier and animate the Gizmo. That should work in this case.
Cheers!
« Last Edit: August 17, 2022, 03:53:54 PM by Paul Roberts »
