Author Topic: Reduce File Size?! - Way to convert FP mesh objects in scene to Xref?  (Read 3978 times)
MoStu
Hi there, we have a scene with many FP objects that the library mesh was merged in the scene. Wondering if there is a way to make the switch to Xref library objects to reduce file size AFTER already populating the scene with merged mesh library object? Ideal if we could keep the same placement/orientation/scale. Thanks for any help pointing us in the right direction!
Re: Reduce File Size?! - Way to convert FP mesh objects in scene to Xref?
« Reply #1 on: April 19, 2017, 12:06:12 pm »
Hi, i'm afraid it cannot be done automatically, but with some manual work this would be the process:
All library models are stored in the "forest_templates" layer.
1) Select the layer and delete all "forest_library_???" objects (but not the "forest_template_???" ones).
2) For each one of the Forest objects, select each one of the items of the Geometry List and assign it from the library again, using the XRef option.
That will keep the existing distributions, but replacing all models. I hope that helps.
