Author Topic: Surface Maxscript  (Read 4625 times)
DN4548
Surface Maxscript
« on: July 02, 2014, 08:04:51 pm »
Hi All, I'm sure this one is really simple but I'm just not sure where to find it. I'm trying to create a forest pack then assign a surface just like you would in the manual method. So far I have this:
Forest_Pro iconSize:1 camfar:100000 cambho:10 camdensfar:1000 clusize:20 altmin:-100 altmax:100
select $Forest001
$.reserved2 = $Plane001
John
DN4548
Re: Surface Maxscript
« Reply #1 on: July 02, 2014, 11:43:42 pm »
This isn't working either. Ah must be so simple!!
tmp_ground=plane pos:[0,0,0] name:"Plane002"
FP4_obj=forest_pro mode:1
FP4_obj.surflist=$Plane002
« Reply #2 on: July 03, 2014, 09:24:07 am »
Yes, as you pointed the surfaces are defined in "surflist", but this parameter is an array. So items are added using "append":
append ($Forest001.surflist) $Plane001
Probably you also want to enable the "Surfaces Area" (if not, there are not visible items). It's done in this way (assuming there are not other areas):
$.pf_aractivelist[1] = true
DN4548
« Reply #3 on: July 03, 2014, 10:31:35 am »
Cheers, That works perfectly!! I'm sure I'll be back with some questions soon.  :)
DN4548
« Reply #4 on: July 04, 2014, 02:58:26 pm »
Ah, told you I would be back. :) How do you had multiple items to the surface in 1 line of code for example
append ($.surflist) ($Plane, $Plane003, $Plane002)
Not
append ($.surflist) $Plane
append ($.surflist) $Plane003
append ($.surflist) $Plane002
Cheers,
John
« Reply #5 on: July 04, 2014, 03:25:20 pm »
it's not exactly oneliner but:
myarray = #($plane001,$plane002,$plane003,$plane004,$plane005,$plane006,$plane007)
for obj in myarray do append ($.surflist) obj
