Author Topic: Forest Objects cause render crash ( mentalRay ) - Max 2015  (Read 3902 times)
suppenhuhn
« on: January 13, 2017, 10:26:28 am »
i got a strange problem caused by forest-objects. The FG calculating time increases dramatically an leads into a crash ( after up to 10 hours precalculating FG freezes at different positions from 5 - 11 % ). See the attached screenshot.
Strange thing is that i'm using own presets-libraries which worked fine during the last projects ?!? Turning the forestobjects off the rendering runs as fast as usually
I'm using 3ds Max 2015 with SP4 on WIN10 64bit
« Last Edit: January 13, 2017, 10:28:42 am by suppenhuhn »
Re: Forest Objects cause render crash ( mentalRay ) - Max 2015
« Reply #1 on: January 13, 2017, 11:45:11 am »
Sorry to hear, you're facing these troubles. Please set the General > Log Level to Debug on one of Forest objects, before sending it to render. There are two logs - one generic for 3ds max located at:
C:\Users\<user name>\AppData\Local\Autodesk\3dsmax\<max version>\ENU\Network\Max.log
and other specific for Mental Ray renderer inside of the Rendering > Render Message window.
Please send us these log files to check it here. Thanks in advance.
suppenhuhn
« Reply #2 on: January 13, 2017, 12:23:00 pm »
Hi, thanks for the quick response!
May i send you a reduced max-file ? Cause we're running out of time and need the render machine to render now and can't "waste" more time on waiting for the crash to send the log-files
« Reply #3 on: January 13, 2017, 12:31:56 pm »
Sure, just let me mention, that we're not always able to reproduce same troubles with provided scene, as it might be linked to something very specific for your configuration (render nodes set-up and so on).
suppenhuhn
« Reply #4 on: January 13, 2017, 01:24:51 pm »
Ok, the scene file is like first aid -> after we finished our actual project ( next Thursday )  i'll send the log files
Ps.S but it's still strange - after i prepared the scene with forest objects only it works fine ?!? The original file works fine when turning the forest objects off - very strange to me
« Last Edit: January 13, 2017, 01:38:34 pm by suppenhuhn »
suppenhuhn
« Reply #5 on: January 13, 2017, 05:56:16 pm »
Where do i find this General > Log Level to Debug settings? @Object Proberties i can't find it...sorry stupid me -> i'll do the log rendering tonight
« Last Edit: January 14, 2017, 03:14:57 pm by suppenhuhn »
« Reply #6 on: January 16, 2017, 10:06:41 am »
Having selected any Forest object, under the Modify tab > General roll-out you can find the Log Level options (None / Normal / Debug). Attaching screen-shot.
suppenhuhn
« Reply #7 on: January 16, 2017, 10:44:30 am »
Thanks ...but as is said stupid me -> i found it ;-) Already sent you the file :)
As i see right now -> you already answered the mail also...Can't repeat it often enough: Wish every company has such a fast support like you  8)
« Last Edit: January 16, 2017, 10:48:21 am by suppenhuhn »
