Author Topic: FP turns off when i save  (Read 3561 times)
mitviz
    • mitviz
« on: April 25, 2016, 11:29:19 am »
is this supposed to happen?
Professional architectural renders
Re: FP turns off when i save
« Reply #1 on: April 25, 2016, 01:20:25 pm »
That's not a default behaviour. Do you experience it with any (new) scene or it's specific just for some? Would you mind to specify more in detail, how it looks once saved - "FP turns off"? A sceenshot will be handy.
It would be really great, if you have a simplified scene where you can reproduce those troubles and you wouldn't mind to send it to us (ideally through WeTransfer to support@itoosoft.com).
Thanks in advance for your collaboration.
mitviz
    • mitviz
« Reply #2 on: April 25, 2016, 03:09:56 pm »
its a large scene and only in this scene i see it, what happens is the layer it creates just turns off, nothing else and only when u save it, so i have to turn in on to see it
« Reply #3 on: April 25, 2016, 04:17:53 pm »
Forest creates a "forest_templates" layer to store there all distributed and templates objects and by default all objects inside this layer are hidden and frozen.
Might be, you've moved that Forest object into this layer? As these objects can be manipulated like any other 3ds max's object (moved to other layer, copied etc.), by moving it under any other layer (like the 0 (default)) should fix it.
Hope that helps.
mitviz
    • mitviz
« Reply #4 on: April 25, 2016, 05:02:21 pm »
aha! it i think i maybe did move it to that layer, i will test it
