Forest Pack => Forest Pro (*) => Topic started by: FD1341 on May 15, 2014, 01:01:20 am
This is a weird problem that whenever I create a forest object it gets place extremely far from the actual surface I am working with. Spline areas and other objects all do the same thing. You can see in the screenshot how far away the FP object lands. I've never had this happen before, restarting Max does nothing to help with it.
Please double check you are using values corresponding to your working units and model size. Under Customize - Units Setup ... you can find it's settings. Check attached screenshot.
If the issue persist, please send us a simplified scene (containing problematic objects) to support@itoosoft.com. For large files, please use a web sharing service as WeTransfer or Dropbox.
Thanks in advance and have a nice day.
Kind regards,
