Author Topic: ivy\vine on column  (Read 1137963 times)
roysgi10
ivy\vine on column
« on: May 11, 2014, 04:20:00 pm »
is there simple way to make thing like that with forest? (climbe on column and beam)
 ( ivy generator is slow and not give me the reaolt that i want)
Thanks.
Roy
Re: ivy\vine on column
« Reply #1 on: May 12, 2014, 11:02:39 am »
As the Forest Pack plug-in is mentioned to scatter objects on splines / surfaces already created there is no option to create branches.
But I can see possible workflow here by using the combination of these two plug-ins:
Use Ivy Generator to generate just branches and Forest Pack Pro to scatter on them using UV mode. Please check screenshots. In this one I used Maple leaves preset slightly scaled down scattered on ivy without generated leaves.
Kind regards,
roysgi10
« Reply #2 on: May 12, 2014, 06:01:37 pm »
Thanks for the idea Michal
