Forest Pack => Forest Pro (*) => Topic started by: Arqrenderz on August 05, 2024, 11:38:59 pm
Title: Forest objects will not render when using Xref object and corona
Post by: Arqrenderz on August 05, 2024, 11:38:59 pm
Hi, we are using max 2024, corona 11.2 and forest 8.2.6
No forest object is rendering when using xref object in the scene, already checked the renderability status, layers and so on..
Is this a known error or are we doing something wrong ?
Title: Re: Forest objects will not render when using Xref object and corona
Post by: RealViz on August 06, 2024, 06:05:56 am
It's hard to say what it is. We have little information. Does it render if the object is inserted directly into the scene (not xref)?. Is it simply a bad FP setting where the densities are too high?
Post by: Michal KarmazĂ­n on August 06, 2024, 08:08:17 am
I'm sorry to hear, you're facing these troubles. If possible, please feel free to send us (https://forum.itoosoft.com/faq/how-to-send-a-file-to-itoo-software/) your scene (ideally simplified and containing just this problematic object(s)). Thanks in advance.
