Author Topic: Vray 3.0 and Forest plane  (Read 3872 times)
Pierre
    • Studiosezz
« on: February 20, 2014, 03:07:47 pm »
I'm using forest 4.2.0b and vray 3.00.01.
When I render my forest plane library , it doesn't work anymore with those versions. I can see my forest in the viewport, but it only render the alpha channel. The diffuse is invisible.
Can you tell me why?
Thank you
¨Pierre
Studiosezz PARIS
www.studiosezz.com
Re: Vray 3.0 and Forest plane
« Reply #1 on: February 20, 2014, 03:49:32 pm »
Be sure you use VRayMtl for your materials (directly or as base material in Forest Material). Standard materials are being deprecated in V-Ray 3.
You can use Material->Optimize Materials to convert them, including your material libraries (new in FP 4.2.0b).
Pierre
    • Studiosezz
« Reply #2 on: February 20, 2014, 04:11:32 pm »
Thank you,
it works. It was indeed the standad materials.
Pierre
Studiosezz PARIS
www.studiosezz.com
in3des
« Reply #3 on: February 25, 2014, 03:17:02 pm »
I'm trying to do the same using a2dimage free plugin, it has quite simple easy settings but... I dont like the result  (((
(http://www.avizstudio.com/tools/a2dimage/)
could you please share your experience
thanks in advance
