Forest Pack => Forest Pro (*) => Topic started by: SR1351 on June 22, 2022, 03:21:19 pm
Title: Forest Pack 7.4.2 Crashes with V-Ray 6 Beta
Post by: SR1351 on June 22, 2022, 03:21:19 pm
Forest Pack 7.4.2 crashed out of 3ds Max when you try to render using Vray 6 Beta.
3ds Max 2022.3
V-Ray 6 Beta
Title: Re: Forest Pack 7.4.2 Crashes with V-Ray 6 Beta
Post by: Paul Roberts on June 23, 2022, 09:51:40 am
Hi, thanks for the report. Are you able to send a minidump  (https://forum.itoosoft.com/faq/getting-the-max-minidump-file/)file to helpdesk@itoosoft.com. It'll help us to diagnose the cause.
Post by: SR1351 on June 23, 2022, 05:08:16 pm
Hey just a quick reply, I tested 3 times real quick and have moved onto a project right now.  But you can easily replicate this, just create flat plane and scatter a teapot onto it. That should crash max instantly.
Post by: iToo on June 24, 2022, 08:41:32 am
Same configuration works fine in our test scenes. Probably something is wrong in your installation.
Please, try this:
- Be sure there are not ForestVRay???.dll files in your Max root folder. If any, delete them.
- Same for forestpackpro.dlo in the 'plugins' folder.
- Reinstall FP 7.4.2. With this version, all plugins files are installed at C:\ProgramData\Autodesk\ApplicationPlugins\ForestPackPro2022 (that changed from previous releases).
If it continues crashing, please send us the minidump to check it.
