Author Topic: FP7 Falling Leaves (Effects)  (Read 4338 times)
iCreateLtd
« on: April 01, 2021, 12:10:31 pm »
Hi.
I'm following the effects video (2016) and just can't get it to work.  I'm probably missing something really easy but I just can't get them to subtly fall.
Is someone able to take a look (asap if possible) and tell me where I'm going wrong?
https://we.tl/t-COq43srd8e
I'm using Max 2019, FP7 & Corona
Many thanks.
Re: FP7 Falling Leaves (Effects)
« Reply #1 on: April 01, 2021, 03:32:43 pm »
Thank You for a question and attached file.
Would You please trying to adjust the effect line:
from Integer -> to Real
Here is the line so You can copy paste it.
Code: [Select]
real speed = randomReal(minSpeed,maxSpeed);
Hope this helps.
« Last Edit: April 01, 2021, 03:42:03 pm by Rokas »
iCreateLtd
« Reply #2 on: April 01, 2021, 04:27:40 pm »
That's perfect & fixed it
Is there any way to add additional wind turbulence to it?
Thanks again for your help
