Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
UV projection Mode
« previous
next »
Print
Pages: [
1
Author
Topic: UV projection Mode (Read 2958 times)
Nico3D
Newbie
UV projection Mode
on:
November 25, 2021, 01:50:29 pm »
Sorry for the basic question.
I have just one layer as "floors" so I need to UV instead XY, but how can I scatter randomizing?
Please check the attachment.
Thank you
Nico
Last Edit: November 25, 2021, 01:58:39 pm by Nico3D
Logged
ITOOSOFT
Hero Member
Re: UV projection Mode
Reply #1 on:
November 25, 2021, 03:57:59 pm »
FP's distribution is map-based, so when using UV mode, areas with the same UVs will take the same distribution and randomisation. To solve this, change the UVs for each layer. Simply moving some of the floors around in the UVW Unwrap modifier should do the trick.
If it helps, we have a detailed tutorial on this topic which you can see here:
https://www.itoosoft.com/tutorials/populate-buildings
Logged
Nico3D
Newbie
Reply #2 on:
November 25, 2021, 04:23:33 pm »
Hi Paul,
Thank you for letting me know.
The UVW Unwrap trick works well...
My problem is that most of the time "floors" are in just one layers.
Cheers
Nico
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
UV projection Mode
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
