Author Topic: Forest Pack Areas Rendering WHITE  (Read 3489 times)
paulmonsef
« on: March 13, 2015, 03:03:40 pm »
See attached image. This started happing in the last month of so and I haven't change anything with the setup/files.
Using Mental Ray, FG, mrSun, etc...
Re: Forest Pack Areas Rendering WHITE
« Reply #1 on: March 13, 2015, 04:17:15 pm »
I would suggest you to do a quick test using the Forest Tools utility to export all scattered geometry to instances. You can find it under Utilities - More ... - Forest Tools. For more information about it, check our on-line reference guide. This way you can check that the problem happens during Forest object conversion or not.
Also, before rendering please remove all Forest Color maps (if any is used) from your materials.
Let us know if there is any difference or not. Thanks in advance.
Kind regards,
