Author Topic: Forest Pack big problem in scene  (Read 4534 times)
MH4288
« on: August 11, 2022, 06:19:57 pm »
I have a serious problem with my scene. I have FP objects in there for a years and reusing it from time to time. Scene is big, but now when I render first image which is ok, stop the render and start the render again whole FP is broken without materials, polygons or something. So I cant finish my scene :(
I installed latest version of FP, maybe there is some error?
I have max 2022 and VRay 5.
Thank you for any help.
MH4288
Re: Forest Pack big problem in scene
« Reply #1 on: August 11, 2022, 06:35:43 pm »
Find out that when I hit render again it is ok. BUT when I save it and then hit render it is broken for no reason. :(
I cant finalize my scene in time for my client because of iToo Forest Pack!
« Reply #2 on: August 11, 2022, 06:51:05 pm »
What do you mean by "broken"? If displayed as a "Mesh" in the modifier then this could indicate the FP Object comes from a non-legit version.
You could try to switch to Item Editor>Custom edit which will basically bake the whole FP object or use the Forest Tools and instantiate the whole geometry.
« Last Edit: August 11, 2022, 06:57:39 pm by Dragan »
MH4288
« Reply #3 on: August 11, 2022, 07:33:17 pm »
No, max and viewport looks ok. But on render it looks like without some polygons or with bad materials. So I delete whole FP object and make it again. One render ok and second terrible again.
« Reply #4 on: August 11, 2022, 09:12:50 pm »
Do you have any animated key frames on your scene?
MH4288
« Reply #5 on: August 11, 2022, 09:18:20 pm »
No, I dont animate anythink. It is just exterior visualization, but large scene, lots of objects.
« Reply #6 on: August 11, 2022, 09:21:10 pm »
Hm, camera limit to visibility?
Hard to say without any more info, any print screen, or the file.
« Reply #7 on: August 12, 2022, 09:23:45 am »
Please try to isolate a problematic FP object and send it to helpdesk@itoosoft.com. The support team there should be able to help futher. As Dragan mentions its hard to diagnose from a description alone.
Thanks!
Arslan
« Reply #8 on: August 12, 2022, 01:39:52 pm »
I had a similar problem too. When I tried the solution mentioned in the link below, the problem disappeared. I hope it helps.
https://forum.itoosoft.com/railclone-pro-(*)/railclone-5-2-2-instant-crash/msg33945/#msg33945
