Author Topic: Forest using open spline - random rotation not working as expected  (Read 4472 times)
antmx
hey, the random rotation isn't working when I use an open spline to distribute my objects.  Translation and scale are, so why not rotation?
I'm on v7.4.1
and how can do I insert an image to illustrate this? I used to do it with a dropbox link but it doesn't seem to be working so I've attached it.
Re: Forest using open spline - random rotation not working as expected
« Reply #1 on: August 08, 2022, 12:51:11 pm »
I can't currently reproduce this issue here, would you mind checking that you don't have Camera > Lookat enabled. There should be no camera assigned, and Use Current Camera should be unchecked.
If this doesn't help, please upload a simplified scene that reproduces the issue and I'll take a closer look.
Many thanks,
antmx
« Reply #2 on: August 08, 2022, 01:30:12 pm »
Thanks Paul, the 'use current camera' was the issue
