Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Mulch to cover slopes equally
« previous
next »
Print
Pages: [
1
Author
Topic: Mulch to cover slopes equally (Read 2781 times)
Crayox
Jr. Member
on:
August 25, 2023, 11:13:30 am »
Hi guys,
is there a way for this FP to cover the weird and streched slopes equally? I tried using UV mode instead of XY but it has it's own drawbacks.
Logged
ITOOSOFT
Hero Member
Re: Mulch to cover slopes equally
Reply #1 on:
August 25, 2023, 11:36:37 am »
Well, the
Scale to fit sloped area
option should be enabled by default for these presets, but on steep surfaces, the
Surface
UV
mode should be used instead of the default
XY
. As mentioned in our
online reference guide
"The UV mode uses the mapping coordinates of the surface as an alignment guide for the Distribution map. This mode is best used on rough terrains or to scatter items over convex 3D objects (as a sphere).
Note that using this mode, the UV coordinates must be precisely defined to get a coherent result.
Logged
Crayox
Jr. Member
Reply #2 on:
August 25, 2023, 12:07:55 pm »
Oh I see. Thanks!
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
