Author Topic: Geometry list display issue  (Read 2726 times)
Viz3D
    • Viz3D
« on: December 23, 2021, 02:29:44 pm »
in the attached images you can see a display issue with the geometry list.
I get it that objects names can't be displayed in full because of the length but I can't see the probability numbers although there's enough space left on the right side of the list. No matter how much I expand the panel, the issue still remains.
I'm using two monitors. A 4k as my main display (150%scale) and a 1920*1200 res screen as a secondary, if that makes any difference.
Is it a problem only on my end? Any thoughts as to how I could resolve it?
3dsmax 2022 and FP 7.1.2
Thanks in advance!
p.s. BTW I would like to remind you of this request I made  long time ago (https://forum.itoosoft.com/forest-pro-(*)/paint-and-erase-areas-using-alt-key/msg22654/#msg22654)
« Last Edit: December 23, 2021, 02:35:04 pm by Viz3D »
Re: Geometry list display issue
« Reply #1 on: December 24, 2021, 01:46:50 pm »
Hi, I apologize this issue was not attended before. For some reason it was not noted in our to-do list.
We already fixed it for next update.
Viz3D
    • Viz3D
« Reply #2 on: December 24, 2021, 01:55:48 pm »
Glad it will be resolved in the next update.
Regards!
