Author Topic: V-Ray 7 GPU, MultiMatte elements ignore Forest objects in include list.  (Read 15222 times)
Bobby Parker
I use PSD Manager by Cebas, and since the newest Forest Pack Pro, the layer masks don't work on Forest Pro elements. I reached out to Cebas, and they pointed me to you guys. I see that this has already been reported. Any fix?
« Last Edit: January 21, 2025, 02:06:42 pm by iToo »
« Reply #1 on: December 23, 2024, 01:07:00 pm »
Please, hold on. We are contacting with Cebas to check this issue.
« Last Edit: January 21, 2025, 02:07:07 pm by iToo »
Bobby Parker
« Reply #2 on: December 24, 2024, 03:19:34 am »
Thank you!
« Last Edit: January 21, 2025, 02:07:17 pm by iToo »
Bobby Parker
« Reply #3 on: January 18, 2025, 12:47:49 am »
Any news on this? It causes significant issues in my workflow.
« Last Edit: January 21, 2025, 02:07:24 pm by iToo »
« Reply #4 on: January 18, 2025, 08:46:28 am »
According to our last messages, problem happens only with V-Ray 7 GPU, so it seems some change in V-Ray.
I suggested them to contact directly with Chaos, because we cannot fix from our side.
I just wrote to the Cebas team again.
« Last Edit: January 21, 2025, 02:07:33 pm by iToo »
RM2551
« Reply #5 on: January 21, 2025, 02:02:22 pm »
To clarify. In V-Ray 7 GPU MultiMatte render elements will not show Forest objects, if they are part of the include/exclude list of the element.
This is not a psd-manager issue. There is no involvement of psd-manager itself, other then that it can export this V-ray produced image data.
If possible please change title so others find it: V-Ray 7 GPU, MultiMatte elements ignore Forest objects in include list.
Workaround 1: assign an Object-ID to Forest objects and enter ID in MultiMatte
Workaround 2: use V-Ray 7 CPU or V-Ray 6 CPU/GPU to render
Status: Bug has been reported in detail to Chaos with sample scene, screenshots, affected versions etc.
Daniel Schmidt - psd-manager Developer
« Last Edit: January 21, 2025, 02:07:39 pm by iToo »
Re: V-Ray 7 GPU, MultiMatte elements ignore Forest objects in include list.
« Reply #6 on: January 21, 2025, 02:08:19 pm »
Thanks for the clarification, Daniel. I changed the post title.
