Author Topic: forest_automat_  (Read 3264 times)
Paulo Beck
forest_automat_
« on: June 04, 2019, 08:58:32 am »
Good afternoon,
I am having problem, I have several objects with ID 1 and however with different UVW. But this forest_automat_ is replacing everything, and a strange green material.
Re: forest_automat_
« Reply #1 on: June 04, 2019, 10:26:09 am »
Dont pick material from forestpack object. It is internal changing material managed by ForestPack.
Use material from geometry used in ForestPack itself:
« Last Edit: June 04, 2019, 10:29:04 am by Rokas »
Paulo Beck
Re: forest_automat_
« Reply #2 on: June 04, 2019, 11:00:13 am »
It did not work yet
Re: forest_automat_
« Reply #3 on: June 04, 2019, 11:13:32 am »
is it the same material for all geometry items?
It would help to understand Your scene if You attached max file.
Paulo Beck
Re: forest_automat_
« Reply #4 on: June 04, 2019, 12:37:34 pm »
I've never had this problem before,
Re: forest_automat_
« Reply #5 on: June 04, 2019, 03:29:08 pm »
Thanks for maxfile but i need texture files as well to check the issue. I do not have any of the maps You use:
Archiving scene would be best way to share max scenes.
Paulo Beck
Re: forest_automat_
« Reply #6 on: June 04, 2019, 03:40:07 pm »
Re: forest_automat_
« Reply #7 on: June 04, 2019, 04:20:49 pm »
Hi. Thanks for scene.
Might it be You are using wrong Tint Map?
Now it is a green leaf with white area and 100% diffuse color override setting on original texture:
Not sure what You want to achieve but let me know, and I will try to help You.
Paulo Beck
Re: forest_automat_
« Reply #8 on: June 05, 2019, 07:45:23 pm »
what a shame!
Thank you!!
