Forest Pack => Forest Pro (*) => Topic started by: GK6439 on June 13, 2013, 05:48:57 pm
Hi, Just installed the new fp403pro and I use max2013 64bit with vray150SP6 and get this message, only when I open up the maps in material editor and my whole max locks up.
I am sure I installed the right version, tried it twice.
Am I doing something wrong?
I looked for similar problems here and found nothing.
This VRay release was released recently (for Max 2013, i mean) and is not supported in Forest.
Really i didn't realize until now of this issue, so i was trying to compile the VRay DLL for you. Unfortunately there are some missing files in the installation package, that we need for compiling.
I just write a post in the ChaosGroup site. I will send you a custom build, as soon as we got the required files.
thanks for your quick response!
should I downgrade vray, or do you think this can be solved easily?
There are not other versions of VRay for Max 2013, (except Vray 2, that works fine), so there are not downgrade options.
Usually ChaosGroup reply quickly. Hopefully we will have the build very soon.
I downloaded and installed max2014 and that seems to work.
was a good reason to upgrade ;-)
wait...
I still get that message, doesnt freeze max anymore though.
That's normal. Max 2013 and 2014 use same DLLs.
I just sent you by e-mail the DLL for VRay 1.5.
thanks carlos!
i have same problem. could you send me a dll. too?
Thanks a lot
Jan
Forest Pack 4.1.2 already includes supports for this VRay version.
Thanks for your reply, but I´m using version 4.0.3, my subscription expired. Any way?
Thanks Jan
I just sent you the DLL by e-mail.
thanks a lot!
