Author Topic: Hedge along a path?  (Read 5032 times)
IT1371
Hedge along a path?
« on: June 25, 2017, 01:32:26 pm »
So I've been playing around with some hedges, and I thought I could make them follow the path with the "Cars along spline" effect.
It didn't work. And I don't want to use Custom Edit.
Is there something new in this field?
I can do it easily with Railclone, but unfortunately when I make such a style it just hogs all the RAM and crashes max.
Re: Hedge along a path?
« Reply #1 on: June 26, 2017, 10:41:50 am »
"I don't want to use Custom Edit."
In such case, the RailClone plug-in would be the recommendation way. To generate just instances, please turn-off Bend & Slice for all used Segments (this will ensure that all these will be handled as instances). Hope that helps.
