Author Topic: Forest Pack Not Rendering Via Backburner  (Read 28999 times)
f9022
« on: October 15, 2024, 01:30:10 pm »
Hi All,
I have an issue with trying to get Forest Pack geometry to render when rendering via backburner. The scene has multiple Forest Pack items for planting that render fine on my workstation however they are missing when I render the scene on our slave PC using backburner.
FP does work via backburner using a simple sphere scattered on a plane in the same scene, so the issue seems to be with the more complex 3d models I am using for the planting in the scene. Using the default 'Max faces' and 'Max Items' on my workstation it renders fine, and all items show however increasing both these values it will cause the render to crash and not start on the slave PC using backburner, usually with an error in backburner saying "3dsmax adapter error: An exception occurred while rendering with 3ds max".
The slave PC has the same 64gb RAM and a more powerful CPU than my workstation PC however it feels like when running the render with the increased 'Max faces' and 'Max Items' the PC runs out of RAM causing the render to crash. Which seems strange as the scene renders fine on the workstation and all the FP items show as expected.
Has anyone come across a similar issue and any ideas on how to solve it would be greatly appreciated!
Fletcher
Re: Forest Pack Not Rendering Via Backburner
« Reply #1 on: October 15, 2024, 01:40:35 pm »
Hi Fletcher,
Would you mind enabling and sending us the log by setting General - Log Level to Debug in any Forest object in your scene before sending it to the renderer? The log file is located at:
C:\Users\<yourUsername>\AppData\Local\Autodesk\3dsmax\<yourMaxVersion>\ENU\Network\Max.log
Thanks in advance for any further comments on this issue that you can share with us and our user community (in case some users will run into similar troubles).
f9022
« Reply #2 on: October 15, 2024, 02:04:19 pm »
Hi Michal,
Thank you for your reply. I have just emailed you the Max log. It seems to crash just after 'Compiling geometry'  when its 'Building Embree static accelerator' also should add that I am on Vray 6.
Fletcher
jedchambers
« Reply #3 on: February 24, 2025, 10:24:22 am »
Hi there,
Was a solution found for this problem? having a simialr issue....
« Reply #4 on: February 24, 2025, 10:42:49 am »
In that specific case, the issue was due to a version mismatch. The problematic node was running an older version of the plug-in.
