Author Topic: install Library on network storage  (Read 33421 times)
effektarium
« on: December 02, 2021, 12:56:51 pm »
Hi there,
how can i prevent FP to add all the local paths to 3ds max external paths?
When i download all with updater he saves everything in c:\users\++++\appdata\local\itoosoftware
So i copied "Forest Pack Pro" folder to my networkstorage and add path in the Library Browser and delete the default path.
But everytime i start max all the default paths are back.
And what is with "distmaps" folder? Is this only working locally?
What would be the correct approach to have the library and all maps on my NAS?
Thx a lot,
Mario
Re: install Library on network storage
« Reply #1 on: December 02, 2021, 02:27:44 pm »
Hi Mario,
First, let me mention, that the plug-in is looking for these assets under paths stored within the following registry key:
HKEY_CURRENT_USER\SOFTWARE\Itoo Software\Forest Pack Pro\LibraryDir
and I would suggest you check this “Installing ForestPack 6 assets in a shared network path” tightly related post regarding the recommendable path configuration.
When the Forest Pack plug-in is loaded, it's checking if these paths exist, but if you want to disable this feature, you can set the checkTexturePaths = 0 in the forestpack.ini configuration file located by default at:
C:\Users\<username>\AppData\Local\Autodesk\3dsMax\<maxversion>\ENU\en-US\plugcfg
« Last Edit: December 02, 2021, 02:57:50 pm by Michal Karmazín »
effektarium
« Reply #2 on: December 02, 2021, 03:03:39 pm »
Thx a lot.
The key was alright.
But I found in HKEY_CURRENT_USER\SOFTWARE\Itoo Software\Forest Pack Pro\TexturePaths there where all paths stored,
local and network ones...
I deleted all local ones, then the distmaps where not found anymore
Maybe i should make a clean install according to your recommended post :)
Best
Mario
effektarium
« Reply #3 on: December 02, 2021, 03:09:41 pm »
It seems to work now. But when i look in the asset tracker its like asset_tracking_01
I have to make the paths absolute, then it seems to work out... (asset_tracking_02)
Do i miss something?
« Reply #4 on: December 03, 2021, 02:03:23 pm »
Well, if it says Found in the Asset Tracking tool for these textures, there shouldn't be any problem with it (although it's not showing the folder). That said, generally, we recommend resolving all references to absolute UNC paths. It's not necessary, but usually, this way you avoid any texture path issues while using distributed rendering.
effektarium
« Reply #5 on: December 03, 2021, 06:27:30 pm »
Ok, thx a lot for your help!
Have a nice weekend,
Best
Mario
Vankar
« Reply #6 on: February 21, 2025, 03:25:23 pm »
Hello! Im sorry to revive this old thread. Is there an updated registry edit for this procedure? I'm upgrading from Forest Pack 6 and would like to know if the information on this link is updated.
https://forum.itoosoft.com/faq/installing-forestpack-6-assets-in-a-shared-network-path/
Thank you!
