Author Topic: Why offset?  (Read 4902 times)
MO4363
Why offset?
« on: April 26, 2013, 12:51:52 pm »
Hello. I have some problem. In the beginning I created scene with using Forest Pack (used Custom Odject). But now I want to change geometry in one rectangle and when I create one more geometry (use Template), it is offset. Why?
Re: Why offset?
« Reply #1 on: April 26, 2013, 12:54:21 pm »
Please, send us a stripped scene, so we can check it. Thanks.
Re: Why offset?
« Reply #2 on: April 26, 2013, 02:13:30 pm »
Thanks for the file. The template objects in this scene are modified, probably because they were merged from other scenes. Please, try this:
- Be sure there are not Forest objects using "Template" (as Forest006). Set them temporary to "Disable".
- Open the Layer Manager, and disable "Hide" and "Freeze" checkboxes of the layer "forest_templates"
- Select all "_forest_template" objects from this layer, and delete them.
- Save the scene, reset and reload.
- Select any Forest object and set a Template. The template objects in the layer will be rebuilt, fixing the problem.
