Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
scattering balcony plants
« previous
next »
Print
Pages: [
1
Author
Topic: scattering balcony plants (Read 4070 times)
yossivida
Newbie
on:
March 14, 2019, 07:03:12 pm »
What is the best way for scattering a large number of balconies with plants?
Logged
ITOOSOFT
Hero Member
Re: scattering balcony plants
Reply #1 on:
March 15, 2019, 08:34:30 am »
As mentioned in the following "
how to: forest on multiple level base geometry (tower balconies)
" post:
"There are several ways how to archive the desired effect and from release 4.1.2 there is a
Randomize Stacked
function.
1) You can use the
UV mode
of scattering on surfaces and then slightly change UV mapping for different levels.
2) Using
XY mode
with the
Randomize Stacked
option marked. To allow the Randomize Stacked function to work you'll need to detach it to several objects and assign them back in the
Surface
tab. This way you can use it also in UV mode."
You might find the
Populating Building Interiors
tutorial helpful, explaining this and a few other techniques more in detail.
Hope that helps.
Logged
yossivida
Newbie
Reply #2 on:
March 20, 2019, 03:14:42 pm »
Thank you Very much!
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
