Author Topic: Forest Pack Pro Octane Renderer Color map  (Read 3002 times)
JD4174
« on: May 08, 2017, 04:00:16 pm »
Hi there at Itoo,
I use the Octane renderer from Otoy. I am trying to get the Forest color map working but until now without result. I attached a jpeg from my setup. Does anybody knows what is wrong? Or doesn t it work at all?
gr Paul JD4174
Re: Forest Pack Pro Octane Renderer Color map
« Reply #1 on: May 08, 2017, 04:50:34 pm »
I'm afraid, the Forest Color map is not supported by the Octane renderer. Please feel free to check the Feature Compatibility table in our on-line reference documentation.
JD4174
« Reply #2 on: May 08, 2017, 04:59:26 pm »
Hi Michal,
Thanx for the quick answer.  Do you know if in the near future FP can scatter on animated, deformable meshes?
Best regards Paul
« Reply #3 on: May 09, 2017, 09:38:15 am »
Hi Paul,
Usually, the UV mode would be recommendable, but it'll depend a lot on how the deformation will look like. For some scenarios (where the UV space is significantly deformed in time) would be recommendable to use a workaround with "help surfaces" as explained in following "Scattering on animated surface" thread. Hope you'll find it useful.
JD4174
« Reply #4 on: May 09, 2017, 10:40:17 am »
Thanx! most usefull.
gr P
