Author Topic: gradient color by height  (Read 2633 times)
Pierre
    • Studiosezz
« on: November 30, 2020, 06:56:10 pm »
hello
I try to reproduce this visual effect without success (see forest.jpg)
 The idea would be to create a color gradient to visualize the height of the trees, regardless of their altitude.
I created a tree with an uvw planar which works if the tree is not modified in forest. But if I apply the scale transform, the uvw is also changed and I get the following result (see forest_render.jpg)
Do you have an idea to achieve the desired result?
Thank you for your help
Pierre
Studiosezz PARIS
www.studiosezz.com
Re: gradient color by height
« Reply #1 on: December 01, 2020, 10:46:24 am »
Using different UV map scale would break the Instancing.
