Author Topic: xref disappearing when reopening files  (Read 3734 times)
danidenny
« on: December 02, 2020, 11:33:28 am »
I'm facing this problem: i made a simple scene, just 1 xref model of a tree and a forest object scattered on a plane,using scattered distribution map. Everything is fine while i'm working but the next time I opened the file the geometry disappears. The forest object is still in the scene, the custom geometry is too but I can't see them!
Any ideas for fixing this problem??
Just to be clear, I have a regular Itoo licence for forest pro. I'll attach some picture for the before and after the problem facing.
Re: xref disappearing when reopening files
« Reply #1 on: December 02, 2020, 12:04:34 pm »
Hi, welcome to the forum.
Would You please attach a max file to check it?
« Last Edit: December 03, 2020, 09:18:24 am by Rokas »
danidenny
« Reply #2 on: December 02, 2020, 06:12:14 pm »
i can only attach max 5mb files...There is a specific way to attach bigger files?
Thank you!
« Reply #3 on: December 02, 2020, 06:14:15 pm »
wetransfer link is fine. If You do not want file to be shared publicly here, You can send it to us.
danidenny
« Reply #4 on: December 02, 2020, 09:02:54 pm »
https://we.tl/t-n4ros2TcFC
file "011_vray" is the native file for the xref tree, file "bug" is the forest object
Thank you!
« Reply #5 on: December 03, 2020, 08:36:38 am »
You are using xref scene, not xref object. May I ask, why ?
danidenny
« Reply #6 on: December 03, 2020, 09:10:32 am »
Because with drag and drop into the scene I can choose open file, merge file and xref file..so I choose xref. Maibe can be a solution to use Xref object importing the old fashion way?
« Reply #7 on: December 03, 2020, 09:20:23 am »
How did You pick that xrefed scene in the "before" scene ?
We recommend using xrefed objects, not xrefed scenes as scattering items.
danidenny
« Reply #8 on: December 03, 2020, 09:49:24 am »
It works!!
I pick up the tree as a Xref Object, saved and opened the file two times and the forest geometry are still there.
Thank you very much for your help and you're fast response!
Have a nice day.
