Forest Pack => Forest Pro (*) => Topic started by: SE1984 on June 11, 2021, 12:42:55 pm
This is the first time i post a question here, may I know how can solve the problem in the red circle? I don't want the grass go the white wall...
You can follow the below tutorial and see if it works
https://www.itoosoft.com/tutorials/edge-mode?back=page%3D7%26tag%3Dforestpack
if not the post again in the same thread will try to help
Yes I have watch and follow the video, it look great for the center patn edge, but it not working for the area in red circle
Try to exclude that geometry from the forest and see if that works
If forest is trying to protrude from the geometry then it will not after you do the setting or if you are trying to achieve like an ivy falling from the geometry then its altogether a different approach.
