Author Topic: Un-even or No Distribution  (Read 3008 times)
Dustin
« on: September 01, 2023, 05:26:20 am »
Im having an issue with a small setup. When trying to distribute on a path, all of the bushes stay close to each other in the middle instead of spreading out onto the path evenly. Is this a setting Im missing? Ive tried every setting. If I try to just distribute the plants on a small plane for a flower planter, there's nothing.
« Last Edit: September 01, 2023, 06:47:57 am by Dustin »
Dustin
Re: Un-even or No Distribution
« Reply #1 on: September 01, 2023, 06:49:42 am »
Interesting find. While trying a closed spline for an area distribution, if I remove the surface from the list, then it works. As far as I know, you always needed a base surface and then a spline to define the area ON the surface you wanted the forest.
« Reply #2 on: September 01, 2023, 08:46:55 am »
Hi Dustin,
As it's really hard to say, what's happening in your scene just from the provided screenshots - if possible, please feel free to send us your scene (ideally simplified and containing just this problematic object(s)) to check it here. Thanks in advance.
