Author Topic: grid look  (Read 3038 times)
SS2980
grid look
« on: April 09, 2022, 10:47:16 am »
I have used one of the lawn presets and I am getting this grid look grass. Maybe is is not noticeable at the first glance but it is just like the grass patches ended at the same place.  I have not touch the settings, distribution is set to full.
Re: grid look
« Reply #1 on: April 12, 2022, 09:27:35 am »
HI,
This is caused by the full distribution map which creates a solid grid of objects. It's the most efficient way of filling large areas but it can have this side effect from certain angles and lighting setups. Fortunately it's quite easy to fix, you can break up the grid by increasing the X and Y random translation values. If you need more you might find that increasing the density helps too.
Many thanks,
SS2980
Re: grid look
« Reply #2 on: April 13, 2022, 08:38:06 pm »
Thank you Paul, it did the trick:)
