Author Topic: Forest Pro exclude railClone objects  (Read 5908 times)
Despondo
« on: March 20, 2014, 08:16:35 pm »
Is it possible to use a railClone object as an exclusion area in Forest Pro?
satoer
Re: Forest Pro exclude railClone objects
« Reply #1 on: March 20, 2014, 11:45:10 pm »
Have you seen the real-time geometry exclusion tutorial?
http://www.itoosoft.com/forestpack.php
then =>  Parametric Areas tutorial.
on 0:30 sec there's a topic "real-time geometry exclusion"
does that work for railClone?
« Reply #2 on: March 21, 2014, 08:47:53 am »
Thanks for the query. I can confirm that RailClone does indeed work as an exclude area with Forest Pack. Just select it from the scene using the Object Area button (in the usual way.  Here's a screen grab from a recent presentation that demonstrates a RailClone stone path excluding grass made with Forest Pack.
Hope that helps,
Many thanks,
« Last Edit: March 21, 2014, 09:18:57 am by Paul Roberts »
on_arte
« Reply #3 on: December 13, 2021, 02:34:55 pm »
I 'm 2hours newbie and I cannot find how to make this function work.
I'd like to consider the RailClone Object as an Exclude Area for ForestPack
Please find attached a exemple scene.
Thanks for your help
Sorry for my bad english...
« Reply #4 on: December 15, 2021, 10:00:04 am »
Thanks for the question. Please try setting the RailClone and Forest Pack's coordinates to world origin (0,0).
Best,
on_arte
« Reply #5 on: January 18, 2022, 06:34:15 pm »
Hello
Thanks for your reply and sorry for my late answer.
Still not working for me in render and display in viewport OK.
Please find attached an exemple file.
« Reply #6 on: January 18, 2022, 09:52:19 pm »
For ForestPack Object: Display>Render>Max items> Increase by x10 or try value 0. Also, for better edge detection You can increase Resolution for Railclone object (Areas>Select Railclone001>Resolution)
For RailClone Object: Display>Render> Uncheck `Use instancing Engine`.
Sorry for not elaborating but I`m at some deadline project.
« Last Edit: January 18, 2022, 10:08:35 pm by Dragan »
on_arte
« Reply #7 on: January 20, 2022, 03:42:39 pm »
It's alive ! Working now.
Thanks Dragan for taking on your time.
