Forest Pack => Forest Pro (*) => Topic started by: iToo_Butler on September 28, 2016, 06:40:10 pm
Title: Forest Pro Issue
Post by: iToo_Butler on September 28, 2016, 06:40:10 pm
Hi all,
I'm having a really annoying, and potentially damaging issue with forest pack.
I'm picking some trees from the iToo Plants 1 library. Namely Bush 6, Bush 7, Flower Bush 1, Linden 3 and Maple 3.
When I render locally they are fine. If I save the file, close it, then go back in, the forest object has lost all it's links again. the reason I noticed is because when i sent it to network render i had no trees. When I then go back in to my file, each of those objects has lost it's link to the tree/bush i chose.
I've rebuilt the forest object many times now and have tried changing the method from xreffing to merging. I still get the same result.
Any idea what might be causing this problem? I'm tearing my hair out over it.
thanks in advance.
Title: Re: Forest Pro Issue
Post by: Michal KarmazĂ­n on September 29, 2016, 10:56:32 am
Sorry to hear, you're facing those troubles. Would you mind to send us (http://forum.itoosoft.com/index.php?topic=3648.0) your scene to have a look at it here? Thanks in advance.
Post by: iToo_Butler on September 29, 2016, 03:28:17 pm
Thanks.
An email is on it's way to you!
