Toggle navigation
Login
Register
Forest Pack
Forest Pro (*)
Reference not working with pivot (FP 7.3)
« previous
next »
Print
Pages: [
1
Author
Topic: Reference not working with pivot (FP 7.3) (Read 3242 times)
RealViz
Sr. Member
on:
February 02, 2022, 03:00:02 pm »
I've now noticed that FP does not respect the pivot manual offset of the ref. object in reference mode. The default pivot is still used.
Logged
ITOOSOFT
Hero Member
Re: Reference not working with pivot (FP 7.3)
Reply #1 on:
February 02, 2022, 03:03:42 pm »
Hi! It should work if you reset the XForm of the reference objects
Best,
Logged
RealViz
Sr. Member
Reply #2 on:
February 02, 2022, 03:16:25 pm »
But that unfortunately ruins the object's rotation :-(
Logged
RealViz
Sr. Member
Reply #3 on:
February 02, 2022, 03:17:03 pm »
I believe that previously this function worked normally without resetting xform.
Logged
ITOOSOFT
Hero Member
Reply #4 on:
February 02, 2022, 03:34:28 pm »
I just checked this in Forest Pack 6, and it would appear to be the same as Forest Pack 7.3. I'll mention it to our dev team, but it may be something Max related over which we have little control.
Logged
RealViz
Sr. Member
Reply #5 on:
February 02, 2022, 04:50:27 pm »
Thanks, maybe I'm just remembering it wrong. The best solution is to select the ref. obj. and then rotate/move them in the local.
Logged
Print
Pages: [
1
« previous
next »
Forest Pack
Forest Pro (*)
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
