Author Topic: Forest Pro Object causes Render Crash  (Read 2970 times)
suppenhuhn
« on: January 18, 2016, 12:01:51 pm »
Hi!
I'm using Max 2015 64bit / WIN 10 and trying to render a sequence with a moving camera. Got one Forest Object in the scene using a Lawn ( large ) preset - with two Object-Exclude-Areas.
Everytime i try render out the sequence - MentalRay crashes at the second frame during the FG process ( no FG File is used ) as soon the Lawn becomes precomputed. This is strange - because at the first frame the Lawn is also visible and renders well ?!?
Without the ForestObject it renders fine.
Any ideas?
« Last Edit: January 18, 2016, 12:05:56 pm by suppenhuhn »
Re: Forest Pro Object causes Render Crash
« Reply #1 on: January 18, 2016, 12:15:04 pm »
Which Forest Pack Pro version are you using? The latest Forest Pack Lite/Pro 4.4.1 version has some mental ray® bugs fixed. Also the Forest Pack Pro 5.0.3 beta comes with another mental ray® bugs fixed. I would recommend you to try those, if you're using an older release.
Anyway, would you please save and send us the minidump file of the crash / mental ray log file? Thanks in advance.
Also, please feel free to send us the simplified scene (containing problematic Forest object(s)) through WeTransfer to support@itoosoft.com to analyse it here.
Kind regards,
suppenhuhn
« Reply #2 on: January 18, 2016, 12:47:25 pm »
Hi!
Thanks for the quick response - i'm using 4.4.1.
I'll try to send you the minidump and/or the scene as soon as possible :-)
suppenhuhn
« Reply #3 on: January 19, 2016, 09:09:47 am »
sent you the minidump file via webtransfer a minute ago - hope that helps.
suppenhuhn
« Reply #4 on: January 20, 2016, 12:12:18 pm »
Hi!
I tried the beta on the mobile workstation only yet - but it works ! :-) The render unit will be tested in a few days.
Thanks in advance
Robert
